Frequency offsets...Transponder
KevUK
Hey guys, im not new to DVBViewer really, but im new to the new version....was using the previous version, 3.6 i believe, and you can make your own transponder lists, by editing the file....now this does not work....so im using Transedit...now the probelm is i cant enter the Full frequency number required, and thus it does not pick up all channels, it misses a few out.
Im using ScanchannelsBDA to get the frequencys and that picks everything up fine..but in Transedit i can only enter E.G 722.1 but in reality i need to enter 722166 as the fequency and i cannot do it anymore..
I hope someone here does understand what im talking about, and can help me out.
Strange I am on the latest version and have rescanned OK using the blackhill specific transponder file (with offsets) I made some month ago.
AK
Ok, if i try and make my own Transponder file, just editing the Europe one, it doesnt work, somehow the program still uses the old transponder file with 60 entrys, instead of my 6 entry file....its really bugging me
Did you set another name in the list and selected the right one? Did you correct the entry 0=#channles?
Maybe you should try transedit from the memberssection.
Have to start the program and from "About" , "configuration folder" you open Transponder file and save a new .ini file there.
Hope this helps you...
in my original post i stated im using transedit and i cant enter the full frequency in transedit, even giving an example...and yes the trasnponder file is the same as the one i used with 3.6
thanks that will help alot.
Thanks Arc, thats solved it, now have all my channels.
Edited by KevUK
Will be fixed in the next release. However, your device should be able to tune such a transponder with 722.1 or 722.2.
