disable audio/video bug
disentis
when i set scheduler recordings in different transpoders only first recording works with turned off audio/video.
if second recording in other transpoder, then audio/video turns on in the beginning of second recording.
Yes this ist correct. disable the graph (menu view), if you don't want to tune in.
i tried Audio/Video disabled and Close Graph.
both don't help.
when this bug will be fixed or how i can avoid this bug?
..just don't call it bug ;)
Whether this bug will be corrected in the next version of DVBViewer?
this is bug.
this function works very bad, it works ONLY in first transpoder.
it is not "Default disable AV" it is "Disable AV ONLY in first transpoder"
option disable is set ON, but after starting of recording in other transpoder decompressing of AV turns on.
when this bug will be fixed?
Edited by disentis
did you stop the graph (in view menu) or just disabled av (for example through minimization)?
first i start DVBViewer, then i add scheduler recordings, then i set audio/video disabled from menu view. during first recording audio/video is disabled.
then when second recording begins and if it is in an other transpoder, then audio/video decopression enables and use my processor.
what "through minimization?" does mean?
Edited by disentis
That's the mistake. Select "close graph"
