Smeghead Posted August 29, 2007 Posted August 29, 2007 Sorry if this isnt the right place, if it isnt please tell me where to post it thanks.... I bought the Twinhan ATSC D+A and its working ok. Model 32500 My problem is im not very impressed with the HDTV quality. I have a comcast HD cable box connected to my cable source, then an Svideo cable going from the HD cable box the ATSC D+A card inside my PC. I can watch HD channels, but I dont get the Comcast menus when on an HD channel, and that usuall means that it ISNT actually 1080i because I went through this before with my Big Screen TV. I dont think im actually getting 1080i like I should. Can you think whats wrong? Quote
Moses Posted August 29, 2007 Posted August 29, 2007 I'm quite sure that S-Video connection is not able to transport a 1080i Signal. You'll need a DVI or HDMI connection. Quote
hackbart Posted August 29, 2007 Posted August 29, 2007 What is with connecting the ATSC-Digital input with your cable junction directly? Christian Quote
jerryt Posted August 29, 2007 Posted August 29, 2007 Sorry if this isnt the right place, if it isnt please tell me where to post it thanks.... I bought the Twinhan ATSC D+A and its working ok. Model 32500 My problem is im not very impressed with the HDTV quality. I have a comcast HD cable box connected to my cable source, then an Svideo cable going from the HD cable box the ATSC D+A card inside my PC. I can watch HD channels, but I dont get the Comcast menus when on an HD channel, and that usuall means that it ISNT actually 1080i because I went through this before with my Big Screen TV. I dont think im actually getting 1080i like I should. Can you think whats wrong? This card would only be HD from the digital tuner. Quote
Smeghead Posted August 29, 2007 Author Posted August 29, 2007 (edited) I'm quite sure that S-Video connection is not able to transport a 1080i Signal. You'll need a DVI or HDMI connection. The PCI card doesnt have those connections. I guess I need to bypass my comcast cable box and go straight to the PCI card with the cable from outside? *update* I just tried that and it only found about 70 channels, my cables providers HD channels are in the 300s I dont get it Edited August 29, 2007 by Smeghead Quote
jerryt Posted August 29, 2007 Posted August 29, 2007 The PCI card doesnt have those connections.I guess I need to bypass my comcast cable box and go straight to the PCI card with the cable from outside? *update* I just tried that and it only found about 70 channels, my cables providers HD channels are in the 300s I dont get it OTA (ATSC = Digital) tuner is HD, NTSC (Analog) tuner is standard definition and will not accept cable HD channels. Try fusion cards Quote
Smeghead Posted August 30, 2007 Author Posted August 30, 2007 (edited) Its supposed to, its a Twinhan ATSC that says 1080i HDTV on the box? I have digital cable too and HD on my big screen tv off the same source Edited August 30, 2007 by Smeghead Quote
