bakerpr Posted August 29, 2007 Posted August 29, 2007 Just updated to the latest core avc 1.5.0.1 and it would appear that DVBViewer crashes on startup with bbchd if directshow deinterlacing is activated.Is this an issue with DVBViewer since there is no issue with playback i other software. Quote
hackbart Posted August 29, 2007 Posted August 29, 2007 The one from yesterday works quite fine with the 3.8.0.0 here. Tested with Anixe and the Astra Trailer. Christian Quote
bakerpr Posted August 29, 2007 Author Posted August 29, 2007 With my setup neither vmr7 or 9 wor properly but if iI change from video renderer to unchanged it seems to have fixed the problem. Btw What does unchanged actually mean? Quote
hackbart Posted August 30, 2007 Posted August 30, 2007 Unchanged means that i dont try to force which videorenderer is used. I hope once we use the new D3D Engine we made in the last months these nagging problems will be history, therefore i expect other problems with graphic card drivers Christian Quote
CiNcH Posted August 30, 2007 Posted August 30, 2007 @ Christian, can you please give us a small status report about the D3D engine? Would really be interesting. Quote
