miro111hrzg Posted August 30, 2007 Posted August 30, 2007 Is it possible to include recording time status in future DVBViewer versions? Quote
Lars_MQ Posted August 30, 2007 Posted August 30, 2007 eyery recording has a time, just look into the timerwindow. Quote
miro111hrzg Posted September 3, 2007 Author Posted September 3, 2007 can you help me finding the timerwindow in DVBViewer? All I can see hours, minutes and seconds of time, but that's not recording time. Quote
Lars_MQ Posted September 4, 2007 Posted September 4, 2007 DVBViewer menu -> Recorder -> before every entry is the recording time and date. DVBViewer menu -> Recording and stats window -> the same. OSD-Menu -> Timer -> the same. enough? Quote
Moses Posted September 4, 2007 Posted September 4, 2007 Are you looking for duration? There is a column in Menu->Timer that shows the duration of a recording. Quote
