Weather in 3.8.0.0
boeda12
I've tried anything but nothing happenes
Edited by boeda12
  • 3 weeks later...
In the Options, under Weather, how do I add my location to the list? I type the name, click Search, and nothing happens ;)
In the 3.8.0.0 Setup the ....\DVBViewer\OSDSkins\Default\myweather.xml is not included you could download it here you although need the "Weather Images for the HTPC" (Members Section) in ...\DVBViewer\weather.
@avoidz
My be your city is not in the Database from wetter.com
@boeda12: have you downloaded the weather-images from the members area first?
@avoidz: the location has to be a valid weather.com location. Go to www.weather.com and search for your location. In the adress bar you can see your location ID (e.g. USNY0996 or GMXX0049). If there are results then the weather plugin should work for you, if not, try a city near you.
You can find the location ID in the setup.xml and change it manually...
Cheereo
NeDrY
@Tjod: damn, you are tooo fast ;)
Edited by NeDrY
Thanks both for the (speedy) help :original:
I downloaded the HTPC Weather Images; now I'll check if I live in a valid city ;)
Brisbane, Australia - ASXX0016
Cheers ;)
