MichelChel Posted September 2, 2007 Posted September 2, 2007 Hello folks. I used DVBVservice and it worked fine with previous version of DVBViewer, but with the latest one, it doesn't start. Icon stays gray. I also have problem with my firewall, which is supposed to manage windows processes and components injections or calls, and the messages/options it shows are particularly unclear to me. Do someone have DVBVService 1.1.2.0 working well with 3.8.0.0 ? TIA. M. Quote
Moses Posted September 2, 2007 Posted September 2, 2007 sercie 1.1.2.0 is not supposed to work together with DVBViewer 3.8.0.0, you should install the latest beta version from the member's section! Quote
MichelChel Posted September 3, 2007 Author Posted September 3, 2007 sercie 1.1.2.0 is not supposed to work together with DVBViewer 3.8.0.0, you should install the latest beta version from the member's section! Ok Thanks. Quote
