How to add an external Graph
Frozen
sorry if that was discussed before ... I have searched but get nothing
If I make an external graph with Graphedit ... where is the root to put inside DVBViewer folder ?!
thanx in advance
Hi!
You need:
1. The "Graph Selector Plugin 1.6.2" (customer area -> "PlugIns")
Unzip -> transport the GRFSelector.dll -> Folder "Plugins"
2. Transport the Sub-Folder "Graphs" -> DVBViewer-Installation
3. Copy "Your" Graph to Folder "Graphs" -> Subfolder:
- "DVBSource2Graphs" (for special-SourceGraph-Handling), or
- "DVDGraphs" (usings Graphs for DVD-Playback), or
- "VideoGraphs" (for .mpg/.ts, etc.)
4. Select "Your" Graph via Menü -> "PlugIns" -> "GraphSelector" -> ...
regards
p.s.: If you want to use "VideoGraphs", take care that "Use DVBSource for MPEG files" ("DirectX") is unticked ...
