Recording Service : Does not put computer back to standby after record
LearningCurve
The recording service will wake the computer up from standby to record. It does not put the computer back to standby after recording. In fact, after waking up from standby to record, it will never go back to standby until I reboot. Under option settings in DVBViewer, I have selected to force to standby after recording. I do not know if this pertains to the recording service. If it is suppose to it is not working.
My set up is as follows:
DVBViewer Pro 3.8.0.0
Rec.Service 1.3.2 beta
XP Pro SP2 with all the latest updates.
Motherboard is an Asus P4P800 MX with P4 3Ghz
1Gb ram
Twinhan 1025 DVB-S
Is there a simple setting I need to change?
THANKS!
the timer must have the after recording action standby not the optionspage.
Thanks, I figured I was missing something simple. :rolleyes:
