aamulla Posted September 3, 2007 Posted September 3, 2007 Dears, I spend hours trying DVB Server, but nothing appear in the client PC (Notebook). The Auto discovery shows the server name but no Sound or Video. I use DVBViewer 3.8 Any Help, Thanks Quote
Derrick Posted December 5, 2007 Posted December 5, 2007 Both: update to latest version from member's area and attach support.zip Quote
docfaustus Posted July 20, 2008 Posted July 20, 2008 Selbiges Problem. Allerdings finde ich auch kein Subnet das nicht rot unterlegt wird. Jemand n Tip ? Quote
EOiN Posted July 24, 2008 Posted July 24, 2008 Selbiges Problem. Allerdings finde ich auch kein Subnet das nicht rot unterlegt wird. Jemand n Tip ? ... versuchs mal mit 255.255.255.0 Quote
Lars_MQ Posted July 25, 2008 Posted July 25, 2008 Naja wohl eher mit 224.0.0.1. Oder noch viel besser, nimm Unicast anstatt multcast. Quote
steven627 Posted August 1, 2009 Posted August 1, 2009 I too had no joy with the server. However, I can offer this work around, which I find works better than streaming. 1. on client pc map a network drive from the server pc (i.e. the HDD that the recordings are stored on) 2. on client pc set the recordings (and timeshift if you like) folder to the corresponding folder on the mapped drive Using the Recordings and device statistics - Recorded Shows TAB. you have direct access to your media. Uses the database refresh if the recording is missing from the list. To stream a live show simply set it recording on the server and then access it from the client as described. You can also use the http server app to remotely control scheduling. N.B. If you delete a program on the server that you have loaded in the client then it will delete it from the database and it will delete the txt file but it will not delete the mpg/ts file. To delete it you must either delete it using the client or manually Quote
steven627 Posted September 7, 2009 Posted September 7, 2009 OK I've worked out my problems with DVB server and suggest that any problems you might have with this are that the configuration details are misleading by stating specific IP addresses, you don't need to use these but rather ones that suit the configuration of your particular network. Often people don't have a static address at all but if you don't want to configure your client every time then the server should run on a static IP address. If you don't know what to set this to, assuming they previously weren't static, they can be any group of 4 numbers between 0-255 although the first 3 must be the same for each PC. The subnet mask for a small network should be 255.255.255.0. If you are using a router then you may need to make some changes to its network config settings. I use a domain so have a server controlling the network so the router only plays a subordinate role, but if you don't have a server and do have a router then this will be controlling the IP assignments. You can work with whatever defaults it has but manually reserve the DVB server PC's IP. Quote
