DVBViewer Pro 3.8.1.xx Beta
Lars_MQ
In the Betasection of the Membersarea is a new beta of the DVBViewer Pro.
This version has some major changes, so don't use it as a produktion system. This is defenitly a beta!
Installation:
You need a working DVBViewer Pro 3.8.0.0 Installation. Make a duplicate of the DVBViewer folder and extract the beta into the duplicate folder. Make a Backup of your datafolder. If you don't know where your data folder resides DO NOT USE THE BETA. It is for advanced users only and not suitable for beginners. :rolleyes:
The best solution, to make sure no data is lost: Work as Admin and use Usermode 0. If you use Vista you are used to living at the edge and with danger so don't worry about your data, usermode 0 won't work for you. :bye:
Make sure to replace the scripts folder in the userdata folder with the one from the beta.
Please post all reports to the english or deutsch beta forum.
Version BETA 3.8.1.0
  • Autoupdate: fixed disappearing EPG due to update with the TID of the previous channel.
  • Channellist: new menu item to en/disable the epg hints.
  • Changed the translation system, the language files do have a different format now. Most language files are already converted. Removed old language files.
  • BDA Devices: Opening a BDA device is now faster thanks to Griga.
  • Channeleditor: Fix for diseqC values not applied on the whole root.
  • Zoom, Colour and EQ window are now one window.
  • Actions.ini: added Zoom75% action.
  • Actions.ini: Added command to reset the most viewed channels list. Best use is with the -x command line. Careful there is no further warning.
  • Inputoptions: export now accepts every folder as destination.
  • Removed the ping on error.
  • Slideshow: now reactivates the last channel not the channel before the last.
  • Channellist: Now dockable to the left or right of the main window. Does not work in skinning mode.
  • EPG options: the Up/Down control didn't activate the apply button.
  • Browsefolder dialog: use now new style dialog. Always centred to the calling window.
  • OSD-Favorites editor: audio subchannels are as separate entries in the list.
  • OSD TTX window: now the same behaviour on number input as the TTX window.
  • Preview completely reworked. Now multi device capable. If you activate the preview it tunes to the current channel. Tuning is done only in the main window. Most of the commands are the same only the channel switch commands in the preview were removed. The same restrictions with the CI apply. h264 channels are not allowed as preview. Channel up/down selects always only allowed channels.
  • Preview Options: completely reworked.
  • Reworked Best windowsize.
  • Aspectratio menu: New item to fit the window automatically on aspect ratio change. Works only with aspectratio auto.
  • OSD-Channellist now has a preview filter and shows only allowed channels if preview is active.
  • Channellist has a new Filter: "Can tune" shows only channels which can be tuned (if recordings are running or preview)(Shortcut F9).
  • Favorites: removed bug on adding from the channellist.
  • Zoom is now dependent on the aspectratio. There are two sets of presets one for 4:3 formats (None, 1:1, 4:3) and one for wide formats (16:9 14:9 etc).
    Depending on the currently used aspectratio the changes in the zoom window apply to one of the sets.
  • DVD-Play: A list of available DVD drives is shown if there is more than one.
  • AudioCD: new inputaction for Play AudioCD.
  • AudioCD: A list of available CD drives is shown if there is more than one.
  • Audiostream change for avi should work now.
  • Networkdevices can be named in the hardware options -> settings.
  • Networkdevices get a unique ID.
  • Fixed moving the mainwindow in vista. Thanks @Griga
  • Reworked the complete mediatags display. A sideeffect: a converted recording (avi etc) will be detected as recording if a info file of the same name exists or if the fileinfos are present (generated with property copy tool from griga).
    Attention: the scripts for the skin are changed. Be sure to use the correct ones, you have to replace the scripts in the userdata folder manually!
  • Options: Removed all playlist settings.
  • Drag'n'Drop of playlists and mixed content in the DVBViewer window is possible.
  • Playlist: Completly reworked. Now the OSD-Playlist and the Playlist use the same data.
  • Playlist is not saved in the setup.xml anymore. Existing data will be converted and removed.
  • Playlist is now saved as playlist.m3u file into the userdata folder. It is loaded automatically on start.
  • Playlist is NOT saved on exiting the Viewer. You have to save it manually.
  • drag'n'drop into the playlist window is possible.
  • OSD Playlist window reworked.
  • OSD Playlist window now selectable in the HTPC menu.
  • ATSC EPG fixed.
  • ATSC autochannel update fixed.
  • ATSC CCSubtitel reworked.
  • KNC One MMI does work now. you need the latest KNCBDACTRL.dll from the current globeTV installation. please copy it into the DVBViewer folder.
  • New Template for recording names "%title". Attention not allowed chars will be deleted and if the entry is too long, it will be cut at 240 chars.
  • OSD Find more... Entries are now sorted by date/time.
  • ID Tags reading reworked and optimized.
  • New commandline: -reset
    Resets all windows positions to the default works only on start.
  • firedtv-s2 fixed a bug on tuning dvb-s2 channels.
  • Optimized program startup.
  • Hardware Device options. New BDA tuning method available. A little bit faster as the old one but is not guarantied to work with every device.
  • Nividia VMR Problem: we hopefully finally found a workaround for this annoying problem. Please test.
  • HTOSD VMR-Fix: Reworked, please test.
Installation:
You need a working DVBViewer Pro 3.8.0.0 Installation. Make a duplicate of the DVBViewer folder and extract the beta into the duplicate folder. Make a Backup of your datafolder. If you don't know where your data folder resides DO NOT USE THE BETA. It is for advanced users only and not suitable for beginners. :mellow:
The best solution, to make sure no data is lost: Work as Admin and use Usermode 0. If you use Vista you are used to living at the edge and with danger so don't worry about your data, usermode 0 won't work for you. :blush:
Version BETA 3.8.1.1
  • Fix crash on startup on Windows < XP
  • Fix Adding or editing virtual path did mess up the z-order of the windows.
  • If "do not tune last channel" is active the commandline parameter -c[channel] was ignored.
  • Maybe fix for FireDTV DVB-S2 and premiere hd, maybe not. untested.
  • Fix for exception in OSD-Theinfos.
  • Fix for played status of videos not set correctly.
  • Fix for crash of TTRemote Inputplugin 1.1.0.
Installation:
You need a working DVBViewer Pro 3.8.0.0 Installation. Make a duplicate of the DVBViewer folder and extract the beta into the duplicate folder. Make a Backup of your datafolder. If you don't know where your data folder resides DO NOT USE THE BETA. It is for advanced users only and not suitable for beginners. :bye:
The best solution, to make sure no data is lost: Work as Admin and use Usermode 0. If you use Vista you are used to living at the edge and with danger so don't worry about your data, usermode 0 won't work for you. ;)
Version BETA 3.8.1.2
  • OSD-Teletext: Fix for some pages were not shown.
  • Playlist: Rightclick now selects the entry.
  • Radiomode: Removed retuning on radio mode switching in the options.
  • Radiomode: is now applied immediatly on radio mode switching in the options.
  • Radiomode: on switching to the next song in the playlist the window doesn't show the videoarea for a short time anymore.
  • Virtual Paths Options: Fixed the browse path dialog on adding virtual dirs is behind the add dialog.
  • Wizard: now uses the same elements for music/video/picture virtual path like the optionspages.
  • Recordings: Changed the valid filename routine, now only the real forbidden chars are removed.
  • COM: Added #selectedmenuitem and #menuitems to the data tags. #menuitems is a commaseparated value list of all menuitems of the current menu and #selectedmenuitem is the index of the currently selected item or -1 if not valid. Can be used with the controlchange event.
  • COM: Added #configfolder and #appfolder to the data tags. They contain a full path.
  • EPG: Optimized the internal handling further.
  • Databases: Several optimizations on the database handling.
  • OSD-Videowindow: Fixed filesize display for files > 8,5 GB.
  • Some general optimizations and small fixes.
Installation:
You need a working DVBViewer Pro 3.8.0.0 Installation. Make a duplicate of the DVBViewer folder and extract the beta into the duplicate folder. Make a Backup of your datafolder. If you don't know where your data folder resides DO NOT USE THE BETA. It is for advanced users only and not suitable for beginners. :)
Version BETA 3.8.1.6
  • Recordings display: Fix for not updating the display on deleting a recordinge entry.
  • Vista: Some small fixes for vista.
  • OSD Skinengine: Fixed a small memory leak on duplicate entries in the fonts.xml.
  • Hints: Fixed the STRG instead of CTRL display in all non german languages.
  • Languages: some updates, included current italiano and suomi language (thanks @gioxy and @sf100).
  • VMR-Fix: Reverted to the old method.
  • Autoplay: Fix for media with videofiles were always auto played.
  • Channellist: If show favourites is selected the channels will be in favourite order now.
  • Preview: Fav +/- was not allowed, removed this.
  • FireDTV DVB-S2: autodetection for upcomming drivers integrated.
Version 3.8.1.7 fixes a bug in the VMR-Fix. :)
Installation:
The best solution, to make sure no data is lost: Work as Admin and use Usermode 0. If you use Vista you are used to living at the edge and with danger so don't worry about your data, usermode 0 won't work for you. :)
Version BETA 3.8.1.10
  • OSD Defaultskin: Several fixes and enhancements thanks @Tjod.
  • OSD Engine: Several small fixes.
  • On some PC crash on shutting the DVBViewer down. fixed.
  • Language files: some updated.
  • VideoSkin: fixed internal crash in Fullscreenmode on mousebuttonpress.
  • OSD-Timers: fixed sometimes the wrong channel was selected on editing a timer.
  • Action.ini: Updated.
DVB-Server:
- Fixed diseqC settings/commandsfile was not loaded.
Netstreaming Plugin:
- Added buffers property to Multicast settings. A Buffer = 188 bytes.
