Problems with DVBViewer
zigger1_2000
Running DVBViewer Pro Beta 3.8.1.1 in Vista with a Skystar 2 I keep getting asked to enter my Username and Password and warned DVBViewer will be closed and must be restarted. I have purchased and have a valid username and password
1. I check the username and password and then click OK
2. I start DVBViewer again and the system keeps repeating the process so I can not have the program running for more than a few seconds.
Any ideas? I have the support.zip attached.
Best Regards
Chris S
Edited by Tjod
Removed wrong Quod marks
This is not a beta problem. The installation instructions state: Make sure you have a running 3.8.0 installation. I'm not wasting my time with people not able to follow simple instructions. :)
Admin - Please delete this post I installed 3.8.0 but did not run it. Also any replies as I made an edit.
Edited by zigger1_2000
Now the next problem I have is that when I change to an encrypted channel it says "No hardware available". Is this normal?
Yes you need a TV-Card with CI the SkyStar 2 is not able th watch encrypted channels.
How did you know that you have a runig 3.8.0 installation if you never start it? :)
If you have used a non legal version of the DVBViewer: Remove it completely- this also includes all of the settings you made as well as the recordings you did. :)
Christian
