GMib Posted September 8, 2007 Posted September 8, 2007 Hello, on my tnt decoder when i display channel epg info if i push left or right i can see next channel epg info without change channel. it's good for viewing other program quickly. on DVBViewer if i push left and right after push enter, it change volume. it is possible to add this into DVBViewer ? thx Sorry for my english. Quote
Moses Posted September 9, 2007 Posted September 9, 2007 Have a look at the OSD Channellist. Isn't that enough? Quote
GMib Posted September 9, 2007 Author Posted September 9, 2007 Have a look at the OSD Channellist. Isn't that enough? thx for tip (i had disable this menu), i will try to edit skin for reduce osd menu. Quote
