kalle173 Posted September 9, 2007 Posted September 9, 2007 Hi Been trying to get DVBViewer to work with my dual tuner DVB-T card. Seems as though only one tuner at time will work. I've tried to use dual instances with DVBViewer Pro and GE and now lately I've tried with DVB server. In the first two cases it says 'no hardware' when i try to start the second instance and when i try the server from to different clients I can see on the server that i get connections but half the time i get streaming values of 0.000MB/s on the second adapter (i.e. the last connection NOT tuner 2) and half the time I get values on the stream but no picture on the client. I've maneged to get picture a few times (about 10-20% of all tries) on both clients when watching channels on the same mux(transponder) but NEVER on differents muxes and not every time even when watching channels on the same mux(feels at bit unstable). I've been reading posts on different forums on how people manage to get this to work either recording two channels or watching´one and recording one, in both cases when the channels are on different muxes(transponders) but I've have never found anyone saying HOW the do it, is it possible or not?? Regards //Kalle Quote
Lars_MQ Posted September 9, 2007 Posted September 9, 2007 Please post some more information: http://www.DVBViewer.info/forum/index.php?showtopic=2210 Quote
kalle173 Posted September 9, 2007 Author Posted September 9, 2007 Please post some more information:http://www.DVBViewer.info/forum/index.php?showtopic=2210 Found a post from you here, stating that i should work with my card i.e. Pinnacle PCTV 2000e (PCTV Dual DVB-T Diversity Stick - USB2) posting additional information in file according to your request.support.zip Regards //Kalle Quote
Lars_MQ Posted September 9, 2007 Posted September 9, 2007 <section name="@device:pnp:\\?\usb#vid_2304&pid_022c#061101045709#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}"> <entry name="HasCI">1</entry> <entry name="UseHardwareFilter">1</entry> <entry name="Name">BDA Digital Tuner (Dev1 Path0) (1)</entry> <entry name="TunerType">2</entry> <entry name="Status">0</entry> well maybe you should simply set the device to use normal instead of do not use in the hardware options. Quote
kalle173 Posted September 9, 2007 Author Posted September 9, 2007 well maybe you should simply set the device to use normal instead of do not use in the hardware options. Checking your suggested course of action shows that the supporttool has made a report on the second instance of DVBViewer Pro, the first instance is the one I've been working with already and it had that status=1 on both tuners so it can't be that. I also checked the file srvhardware.xml and there both devices had status=1 and still i had problem with the server using both devices. It's a little bit frustrating beacuse there is both the program directory with files to manipulate and you have a directory under application data with files to check. The problem might be that I've tried many things on the same machine, two instances and server and so on. What i really want to do is to record two channels on different muxes at the same time, I've be checking around a little bit in different files and i guess what i'm asking is: what are the settings i have to do i hardware.xml, usermode.ini etc to make it work if a do a clean install? Regards //Kalle Quote
Lars_MQ Posted September 9, 2007 Posted September 9, 2007 forget the instancing thing. Use ONE DVBViewer. It can handle everything. By playing around with no plan you only archive one thing, nothing will work anymore... So concentrate on one instance of the DVBViewer. Delete the hardware.xml of this instance and let the Viewer detect the devices again. then you just start one recording and try to zapp to another mux. Quote
kalle173 Posted September 9, 2007 Author Posted September 9, 2007 forget the instancing thing. Use ONE DVBViewer. It can handle everything. By playing around with no plan you only archive one thing, nothing will work anymore... So concentrate on one instance of the DVBViewer. Delete the hardware.xml of this instance and let the Viewer detect the devices again. then you just start one recording and try to zapp to another mux. Well it didn't work the first time, that's the reason for me starting to experiment with dual instances and server and so forth. But I'll do a clean install and try from scratch (at least it will probably be easier to identify any problems after the installation). -"I'll be back" Regards //Kalle Quote
kalle173 Posted September 9, 2007 Author Posted September 9, 2007 I have now made a complete reinstall of DVBViewer and tried exectly as you said AND I've also been trying to record on one mux and then record from another in the epg in BOTH cases the first recording stops and when I choose "Recorder statistics" from the "DVBViewer"-menu and switch to the "device status" tab its exactly as before, the latest instanciated recording is growing in size and the first one is static . Adding the latest supportfile from the only installation on the machine now. Regards //Kallesupport.zip Quote
Lars_MQ Posted September 9, 2007 Posted September 9, 2007 please start the DVBViewer with the -debug commandline and try it again. then post the support.zip again, maybe I find in the debug.log a reason why it doesn't work for you. Oh and please rename the plugins folder to plugins2. And remove the has CI and the Send only encrypted Channels in the hardware options. This stick has no CI so the settings have no effect. Quote
kalle173 Posted September 9, 2007 Author Posted September 9, 2007 please start the DVBViewer with the -debug commandline and try it again. then post the support.zip again, maybe I find in the debug.log a reason why it doesn't work for you. Oh and please rename the plugins folder to plugins2. And remove the has CI and the Send only encrypted Channels in the hardware options. This stick has no CI so the settings have no effect. Done, The debug.log contains two recording sessions beacuse I forgot to rename the plugins folder during the first one. In the second I made the renaming. support.zip Regards //Kalle Quote
kalle173 Posted September 19, 2007 Author Posted September 19, 2007 Any progress? I have now tried on another machine with a fresh vista installation and EXACTLY the same problem, as soon as i start the second recording (or if watching one channel and start to record another) the first one freeze until i stop the second recording, than the first one starts again. And here (post #8) it says it should work. Regards //Kalle173 Quote
Lars_MQ Posted September 19, 2007 Posted September 19, 2007 It does work. I'm using it all the time with the FTA channels here. Quote
smv1210 Posted September 20, 2007 Posted September 20, 2007 It does work. I'm using it all the time with the FTA channels here. On my personal DVBV using experience, I noticed that it is very sensitive of what video/audio codecs are used… Are You sure you do use the same? Quote
kalle173 Posted September 20, 2007 Author Posted September 20, 2007 QUOTE(Lars_MQ @ Sep 19 2007, 10:37 PM) It does work. I'm using it all the time with the FTA channels here. On my personal DVBV using experience, I noticed that it is very sensitive of what video/audio codecs are used… Are You sure you do use the same? Ok Thanks for the tip. I'll try a bunch of different codecs. -Lars_MQ, care to check your working setup(codecs)? would be much appreciated. Regards //Kalle173 Quote
DarthSlarti Posted April 18, 2011 Posted April 18, 2011 Waking up this thread when I have the exact same problem. I have also tried all sorts of settings,both with recording service and straight from dvbv, all with same result. Kalle173: Did you ever solve this? Last post regarding codecs seems a litte bit weird when it works just fine with one tuner at the time. Would be grateful if anyone who have this setup working could provide their settings. Thanks. Quote
Lars_MQ Posted April 18, 2011 Posted April 18, 2011 Please post some more information: http://www.DVBViewer.tv/forum/index.php?showtopic=2210 Quote
kalle173 Posted April 18, 2011 Author Posted April 18, 2011 Back from the dead Jo du hade rätt ang. land DarthSlarti! But no unfortunatly I've never got it to work. I fact I stopped using the prog after this thread. Blev så irriterad på deras attityd att "jo det funkar". Might consider it again if you get to work, we'll see. Regards /Kalle Quote
