Markku69 Posted September 10, 2007 Posted September 10, 2007 Hey, i uninstall previous version 3.6.xx and install 3.8.0.0. next i try install rec. service but when i click "installsvc.bat" come errormessage Next i install 3.8.1.2 Beta and try again install rec. service, same resault. how i set working rec. service? 3.6xx work fine, i don't believe any hardware problem. specs: Anysee E30 usb-digitv Asus A7V880 motherboard Radeon 9600 pro all devices use latest drivers. attachments supporttool infofile. support.zip Quote
Moses Posted September 11, 2007 Posted September 11, 2007 (edited) type "services.msc" in start->Run and have a look if there is a DVBViewer Recording Services entry, somewhere... maybe the old service wasn't deinstalled correctly. If so try to run the deinstall script once again. Of course you need to be administrator for all that! Edited September 11, 2007 by Moses Quote
Markku69 Posted September 11, 2007 Author Posted September 11, 2007 Thanks a lot Moses, you are my hero!!!! i make one test timer-recording and work. hallelujah amen hurrey hurrey... i hope everething is ok now. Quote
