brian45 Posted September 13, 2007 Posted September 13, 2007 Hi ! I have downloaded a lot of skins, but there are no files with skin extensions. Can anyone explain that ?? Brian Quote
Tjod Posted September 13, 2007 Posted September 13, 2007 Most skins are zip you have to unzip them first. And there are to kinds of Skins GUI-Skins *.skin witch should be in ..\DVBViewer\skins. And ODS Skins witch are many *.xml files and Images, thy should be in ...\DVBViewer\OSDSkins Quote
brian45 Posted September 14, 2007 Author Posted September 14, 2007 Most skins are zip you have to unzip them first.And there are to kinds of Skins GUI-Skins *.skin witch should be in ..\DVBViewer\skins. And ODS Skins witch are many *.xml files and Images, thy should be in ...\DVBViewer\OSDSkins I want for ex the xbox skin. I downloaded the OSD xbox skin wich contain the xml files and images. Do I have to download GUI-skin for xbox to ? / Brian Quote
Tjod Posted September 14, 2007 Posted September 14, 2007 No the GUI Skin is for the Menus in the window mod. http://rago.deviantart.com/art/Fusion-1-2-English-40272635 The OSD Skin is for the On Screen Display (to open OSD-Menu pres [Esc] or to open mimiEPG [Enter]). If you have installed a skin you have to select it if you like to use it. (Options>OSD Skin); (Options>Appearance) Quote
brian45 Posted September 14, 2007 Author Posted September 14, 2007 No the GUI Skin is for the Menus in the window mod. http://rago.deviantart.com/art/Fusion-1-2-English-40272635 The OSD Skin is for the On Screen Display (to open OSD-Menu pres [Esc] or to open mimiEPG [Enter]). If you have installed a skin you have to select it if you like to use it. (Options>OSD Skin); (Options>Appearance) Thanks, was that easy that you only have to press Esc to enter the OSD skin ! Now I will go on and test different OSD skins. /Brian Quote
avoidz Posted September 18, 2007 Posted September 18, 2007 I appreciate the help in this topic. It wasn't obvious to me either to press Esc to enable the OSD menu Quote
