Zero7 Posted September 14, 2007 Posted September 14, 2007 (edited) I bought DVBViewer Pro 3 days ago and trying to learn the things. Highly appreciate the effort put in by all of you here to create a good piece of software. I do not want to use the keyboard and mouse for daily usage of the software and I use this mainly as HTPC. I prefer to use the remote came with Skystar2 PCI card for now and a universal remote in the future. I have URC 8901 programmable remote as well. 1) How to map Technisat TTS35 remote (with USB-IR reciever) to the HTPC functions? 2) ESC button of keyboard is not mapped to any button on the remote. I need it to be mapped or else I can't go back to previuos screen / main screen while using the remote. 3) Enter button (KB) is not mapped to "OK" in myHTPC application. Is there a English manual for the HTPC portion of DVBViewer. I checked all posts and read complete instructions available here. But found that all the things talk only about DVB portion of software. Any help is highly appreciated. Edited September 14, 2007 by Zero7 Quote
Tjod Posted September 14, 2007 Posted September 14, 2007 You can Learn every Remote Control key to the function you like. Go to Options>Input -> Learn -select the command> press the Remote Control key> Save You should Learn OSD-OK,OSD-Up,-Down,-left,-right,-Red-,Green,-Yellow,-Blue,-Menu. Quote
Zero7 Posted September 14, 2007 Author Posted September 14, 2007 You can Learn every Remote Control key to the function you like.Go to Options>Input -> Learn -select the command> press the Remote Control key> Save You should Learn OSD-OK,OSD-Up,-Down,-left,-right,-Red-,Green,-Yellow,-Blue,-Menu. Thank you Tjod. Once I go back home from work will try. Quote
