trifon33 Posted September 14, 2007 Posted September 14, 2007 Hello: S2 3200+CI Driver 4.4.10.18 CAM AStoncrypt 2.** "Show CAM" >> little window pops up >> at that step, unable to acces CAM infos. Is that known software limitation? Cheers Quote
Moses Posted September 15, 2007 Posted September 15, 2007 MMI with S2 3200 is terribly slow! Let the device recieve a FTA channel for at least some minutes, before you try... another problem is the cable from the card to the CI Module. Better check that twice or even more often... if nothing helps, try the original Software, because it has the functionality to reset the CAM, which seems necessary sometimes. Quote
