navman Posted September 15, 2007 Posted September 15, 2007 I have notices a problem after upgrading from 3.6 to 3.8. All recordings recorded both with 3.6 and 3.8 cannot play back anymore. When selecting a recording for playback, DVBViewer simple does nothing except for playing the "Windows default beep" (ding.wav). All recordings played back fine in version 3.6. I have recorded in *.ts format. I have noticed that I can play the recordings with the TSPlayer. What went wrong during this upgrade ? Thanks Quote
Lars_MQ Posted September 15, 2007 Posted September 15, 2007 Please post some more information: http://www.DVBViewer.info/forum/index.php?showtopic=2210 Quote
navman Posted September 15, 2007 Author Posted September 15, 2007 Thanks for a very fast response. I have attached the support.zip file. Btw I forgot to mention that after upgrading to version 3.8.0.0, Close Graph and Rebuild Graph (in View menu) does not work either (did work in 3.6.0.0). Selecting either of them also plays the ding.wav sound. Thanks in advance support.zip Quote
Lars_MQ Posted September 15, 2007 Posted September 15, 2007 Please rename your plugins folder in the DVBViewer folder. Does it work then? Quote
navman Posted September 15, 2007 Author Posted September 15, 2007 Yes it does I think I have figured out what might cause the problem. Thanks Quote
