Dvbserver + Diseqc
bobirab
What type of diseqc does it support?
I have a floppydtvs2 and use GoTo angular in DVBViewer, it works perfectly.
But when using dvbserver, the motor moves but not to where it should.
Does dvbserver use positioner or angular?
EDIT: When trying to tune hotbird 13e the motor moves almost to its centre point.
Which would imply that it, if using USALS it thinks its longitude is around 13e..
So is it possible to change the latitude/longitude on dvbserver?
Bearing in mind, DVBViewer works perfectly.
3.8.1.2 beta
Thank you
Edited by bobirab
