Channel name
Accuphazee
Greetings! That it is necessary to make, that names of channels were correctly displayed (on 36E NTV + they in Russian). Otherwise they look - ÁßÞàâ ÛÐááØÚÐ? Thanks
DVBViewer 3.8
P.S. TT S2-3200 (bda 4.4.10.18), ASUS P5WDG2-WS (975X), ASUS GeForce 7900GTX, Win XP Pro eng(SP2)
I think it's not too big work to add string charset conversion from iso-8859-5 to cp1251
That is you suggest any user to enter names of channels manually (if these names in regional language - for example Russian, Spanish...!?). Very constructive thought. And it seemed to me for this purpose programs and create? Thanks.
P.S. Simply it would be desirable, that this problem has been solved in new releases of the program.
EPG - also problems (on russian).
Edited by Accuphazee
  • 3 weeks later...
No problem with Russian EPG now.
But channel names aren't correct yet.
YES, EPG (russian)- all O.K.
YES, EPG (russian)- all O.K. In version 3.9 the problem of display of names of channels in regional languages till now is not solved.
Beg you pardon!
No problems with Russian at all.
Just change encoding to “iso-8859-1” in *.xmls
