Unicast Network Device and diseqc
tommyo123
I can't get diseqc commands working with Unicast Network Device. I've a s2-3200 card connected to a 8 port diseqc switch. This works very well sending raw diseqc commands on machine where the card is installed. Unicast Network Device works fine, but no diseqc commands get through. Have been trying with sending commands twice and increasing the pause between commands, but no success.
It seems to me that diseqc commands over unicast network device might not be implemented? Can anyone confirm if this feature works or is implemented.
No it does not work. The server does not load the commands. I'll fixed it hopefully.
The server needs the same diseqc commandfile in it's userdata folder as the clients. so the best way: create your complete channellist and diseqC stuff with the DVBViewer locally on the pc where the server runs and deploy the channels.dat and the DiSEqC.xml file to each client.
The update will bein the next beta.
