badtrip Posted September 21, 2007 Posted September 21, 2007 (edited) Hi There.. Just a new newbie here.. I purchased my DVBViewer, tried it, it was working fine ... and then formatted my computer for better processing times. First of all i loaded TS342drivers, the program was working fine, then i thought that it would work with the new drivers, so i updated my to 4.2.2.6 version After that installation i found out that my DVBViewer doesnt recognise my skystar dvb card anymore.. neither transedit, nor DVBViewer are working I didnt even have time to play a little with DVBViewer after purchasing it. Then i tried driver versions, 340 - 342 - 4.2.2.1 Now my skystar works on 4.2.2.6 driver but none of them worked... Mytheatre and Altdvb just work fine. I dont get it.. I hope someone could help me about this problem..i really need i also Uploaded the support.zip file incase you need it... By the way DVBViewer version is 3.80 Thank u.. support.zip Edited September 21, 2007 by badtrip Quote
badtrip Posted September 24, 2007 Author Posted September 24, 2007 Could anyone here help me solving my problem please? Its my 6th day after purchasing my software without even using it.. Quote
Lars_MQ Posted September 24, 2007 Posted September 24, 2007 according to your support.zip there is no skystar installed. Most likely you did not install the complete technisat software when changing the drivers. Quote
badtrip Posted September 24, 2007 Author Posted September 24, 2007 (edited) according to your support.zip there is no skystar installed. Most likely you did not install the complete technisat software when changing the drivers. But my card is installed.. I also have some other dvb programs running in my computer.. I'll try as you said and contact later, thank you for your reply.. Edited September 24, 2007 by badtrip Quote
Lars_MQ Posted September 24, 2007 Posted September 24, 2007 But my card is installed.. That is no answer to: Most likely you did not install the complete technisat software when changing the drivers. Did you install all or did you only install the driver? Quote
badtrip Posted October 3, 2007 Author Posted October 3, 2007 (edited) Thank you Lars... I did as you said Then executed the program.. İt works fine, right now but still i have a problem! It consumes all my cpu after a while.. My comp freezes. after ctrl+alt+del everything is fine but DVBViewer isnt Edited October 3, 2007 by badtrip Quote
