SatCoDX
GmY
have a look at www.astra.com and www.hotbird.com
and for HotBird 1-5 (link not work...  )
That's true, the link doesn't work - don't know what they have done to it.
Try to import the txt-file instead by using the ImportSatcoTXT.dll. Just replace csv in the link by txt. It still works - I just tried.
Please note:
- It doesn't work, as long as the ImportTPL.dll for TechniSat Program Lists is in the DVBViewer/Plugins folder, because the DVBViewer can't handle two import plugins which refer to the same file extension (*.txt in this case). If you want to use the ImportSatcoTXT.dll, you first have to remove the ImportTPL.dll or rename it to ImportTPL.dlx, for example.
- It doesn't contain the name of the satellite position. Therefore the plugin has to derive the root folder name from the filename of the imported list. 0192.txt will simply become "19°E", for example. If you give the file a non-numeric name before importing it (for example "Astra 19°East"), it will be taken as the root name.
Griga
ok! :blush: . only my problem is teletext pid... is very small problem... o:)
bye thanks !!
