How to define channel numbers
jekuli
What is the trick in creating channel numbers?
I can define favorite numbers and attach relevant commands to remote controller (Shit 1, Shift 2, etc...).
But naturally I can not then send plain numbers from remote, since they are all shifted numbers (!"#¤...)
However, when showing EPG, the channels are not in any kind on order that I can make sense of.
This is plain DVB-T receiving (no satellite stuff).
There must be some (easy) way of doing this channel numbering stuff...
Ok,
I got it! i created new channel group and dragged all the channels there and sorted them to correct order.
Now, if I only could get rid of channel number 0, then I would be happy. i would rather start channel numbering from 1.
how about creating a dummy entry for channel number 0 ? Afaik that is the only way to start with channel number 1 with the "real" stations.
C.U. NanoBot
