dorijan Posted September 26, 2007 Posted September 26, 2007 Hi If you are streaming hole transponder and programs are coded, and watching them with VLC, only one channel is vieweable, and that is the one that is curently watching in dvbwiever... Quote
dorijan Posted September 26, 2007 Author Posted September 26, 2007 Yes that's correct. is there any way to have more than one program viewable? maybe if I run multiple istances of DVBViewer (is this possible) and than have one (master) DVBViewer streaming to all client dvbviewers and then they stream pure stream... is that possible? Quote
Lars_MQ Posted September 26, 2007 Posted September 26, 2007 Of course it is possible you only need for 5 Channels: 5 DVBVewer instances, 5 DVBCards with CI, 5 CAMs and 5 subsciption cards. Quote
dorijan Posted September 27, 2007 Author Posted September 27, 2007 Of course it is possible you only need for 5 Channels: 5 DVBVewer instances, 5 DVBCards with CI, 5 CAMs and 5 subsciption cards. great... So I would not have problem with licencing of 5 istances of DVBViewer on same computer? I will post here results... Goal would be streaming of 5 different channels with h264 compression... I think one q6600 core2quad would do the job Quote
