Vista 64 or 32?
ramonchin
I'm going to improve my HTPC hardware, and I'm thinking about install Vista. What version is better if the main purpose is DVBViewer use?
Thanks
XP :unsure:
If you realy want to go onto the vista adventure, you should be absolutely sure that there are all the necessary drivers for 64, then it might work.
If you really want to use Vista, DVBViewer works on both, Vista 32 and 64 bit. But it will only run in 32 bit mode. But that's no problem :unsure:
