DVB Viewer Options problem
Javichu1984
Hello.
Since yesterday I have a big problem...the thing is that yesterday I installed a new proyector, and I had updated my Graphic card driver...(ATI 9600)
I switch the tow monitor options to watch the projector....well....
The thing is that now, when I open the DVBViewer and select options, it does not appear the menu options...or when I select the record settings instead of the record settings menu, it appears a "tick" like when you select record...
I think that this menus are "virtually" on the other monitor, and i said virtually, becouse the second monitor is disabled....how can i solve this?
If the menus are in the oter monitor, wich is the config file of the menus?
Thank you a lot.
post a support.zip or at least say which version of DVBViewer you are using.
If you are using the latest beta, have a look at the last entry of the in tweaks.txt. That should solve your issue.
Thank you a lot for your reply......I have solved it right now, by conecting the projector again to the PC and correct, all the options windows was on the other screen but the screen was disabled so....
Thank you a lot!
Bye!
