DishPro setup on DiseqC
jrusa
Hi:
could somebody tell me how could I set DiseqC as OCS DP (DishPro DN 500)?
my LNB config:
COM 1: sat 119
COM2: sat 110
thanks in advance
jrusa
Edited by jrusa
I'm afraid nobody here will understand what you're talking about.
my LNB config:
COM 1: sat 119
COM2: sat 110
..could you translate this to standardized terms or give more information?
The links don't provide useful technical information. You could try to find out yourself by permutating the diseqc settings (A/A, B/A, A/B, B/:blink:. If a scan finds the wanted channels, you've got your diseqc setting for this particular satellite :unsure:
I tried but I didn't found useful information to "permutating" your current A/A, A/B, etc. to DishPro DiseqC setup. The issue is need to set the correct Port to each sat (Por t 1 to Echostar 7 and Port 2 to Echostar 110). Some others DVB software (like MyTheatre) already handle the DP setup.
Maybe will be an advantage for you if you include this handle as a feature on your application
Some information found maybe useful to implement this feature:
http://www.dbstalk.com/archive/index.php/t-5914.html
http://ekb.dbstalk.com/dish500.htm
http://www.dbstv.com/u_dish_network/DishNet_DishPro_QnA.pdf
jrusa
