Black Screen and No sound....
mazinga65
Hello! I've installed DVBViewer V3.8.0.0 + DVB Task Scheduler v 2.1.0 on WINDOWS XP SP2.
Sometimes happens that when DVBViewer start, the screen is black and there is no sound!!!!
If I close DVBViewer and I start again the program, all works correctly!!
In attach the support.zip....
Regards!
Happens to me quite a lot as well, but most often just black picture WITH sound when I start the program. I need to close and restart the program a couple of times before picture is shown. I use Cyberlink 7 decoders with a Twinhan 2033 dvb-c card.
@mazinga65
Try DVBViewer 3.9.0.0 with the CyberLink Decoder.
@jugglan
Pleas post your support.zip (link above this topic)
@mazinga65
@jugglan
Ok, Now Works!
Regards
