Watching active recording
mirc0n
I cannot anymore watch active recordings since it seems that the recorded file is in use.
I have been using DVBViewer probably two months now and I have been previously
been able to watch active recordings..
It is possible that it doesn't work anymore because I have changed the version of DVBViewer.
Now I have the latest beta in use. Not sure though when it it started to work like this.
Has this kind of change been done on purpose for some version?
Is there some option / hidden feature which I can enable/disable to be able to watch recordings
again?
make sure use dvbsource for files in options/directx is enabled.
