linusalba Posted August 20, 2003 Posted August 20, 2003 Hi! I've an idea for a new zoom option. I'd like to see a movie as it appears here removing the 2 black bars up and down. Final image appears as here: I can do this disabling "aspect ratio", changing vertical stretch in zoom option and then resizing the video, but It's not easy to keep the correct aspect ratio. I'm sorry for my poor English thanks a lot for DVBViewer, Marco Quote
Klausing Posted August 20, 2003 Posted August 20, 2003 I think you mean the same thing like this thread. For looking its OK, but i don't think that this work for recordet MPG-file. Steffen Quote
linusalba Posted August 21, 2003 Author Posted August 21, 2003 I think you mean the same thing like this thread. It's not the same, that is what hackbart supposed, a sort of Minimum for Blackbars around the Video. This is a crop video during watching tv, not in recorded video. Thanks for your answer. Bye bye from this hot Italy Quote
Griga Posted August 21, 2003 Posted August 21, 2003 I can do this disabling "aspect ratio", changing vertical stretch in zoom option and then resizing the video, but It's not easy to keep the correct aspect ratio I think I know what you mean - you want the DVBViewer to do this automatically. It will be very difficult, however, since the DVBViewer can't "see" the picture like you see it. It had to analyze the picture permanently to find out if there are any unused parts that could be left out... and as the whole picture processing is done in the filter graph, the analyzing actually has to be done by a filter. Maybe you can write to Microsoft and ask them for a new Overlay Mixer or Video Renderer that provides some "picture size without black bars" query function Nevertheless it should be possible to facilitate the manual cropping - e.g. a function for resizing the window without affecting the TV picture size. Let's see what Christian thinks about it... Griga Quote
linusalba Posted August 21, 2003 Author Posted August 21, 2003 Nevertheless it should be possible to facilitate the manual cropping - e.g. a function for resizing the window without affecting the TV picture size. This is what I'd like By the way, does anyone know Totò, the old italian actor on the left in the picture? Bye Marco Quote
oaks Posted August 23, 2003 Posted August 23, 2003 but all of this solutions do not solve the problem of overlay tv output (the black bars are still there, so on tv no real widescreen is possible - only zooming in - and that looks awfull on my tv-set) i didn't find a way to do it directly, but maybe it's a hint for someone to find a solution: i'm able to watch a non 16:9 movie on my tv in widescreen in 2 1/2 passes: - record the movie with DVBViewer - process the file with dvd2avi, create an avi-synth script cropped and ev. resized (with gknot), add audio stream manually to the avs file - open the .avs file directly with my mediaplayer so i get widescreen 16:9 overlay output to my tv (but it's a little bit tricky... ) Quote
Klausing Posted August 23, 2003 Posted August 23, 2003 process the file with dvd2avi, create an avi-synth script cropped and ev. resized (with gknot), add audio stream manually to the avs file sounds interesting!!!Would you make a little manual for this and put it in conversion&encoding? I mean the part after dvd2avi. Is there a way to do this with SVCD to? Steffen Quote
BadONE Posted August 31, 2003 Posted August 31, 2003 [Nevertheless it should be possible to facilitate the manual cropping - e.g. a function for resizing the window without affecting the TV picture size. Let's see what Christian thinks about it... ] That's exactly what I'd like to have as well. Another thing, that would be very useful - please add sort of "Save Settings" button to the ZOOM function, so you can save a few optimized settings for yourself. Would be useful with the use of broadscreen monitors, which I'm thinking about getting one. 2. Would be nice to have more items in the "Favourites" list, and to improve the handling of this list Other than that I'm pretty happy with the program, ordered the full version just a few days ago. Keep up the good work! Quote
Guest Oliver Posted August 31, 2003 Posted August 31, 2003 Would be useful with the use of broadscreen monitors, which I'm thinking about getting one. The full version features the "best width" function which automatically adjusts the pictures width to avoid black borders, but in certain cases it may be useful to have predefined settings. 2. Would be nice to have more items in the "Favourites" list, and to improve the handling of this list That's already possible with the new MenuCreator plugin from Griga. Have a look here. Bye, Oliver Quote
BadONE Posted August 31, 2003 Posted August 31, 2003 That's already possible with the new MenuCreator plugin from Griga. Have a look here. Yes, but would be nice to have the favorites being accessible via the OSD as well .. Quote
BadONE Posted August 31, 2003 Posted August 31, 2003 That's already possible with the new MenuCreator plugin from Griga. Have a look here. Yes, but would be nice to have more then 10 favorites being accessible via the OSD as well, which I guess is not possible with the plugin, that is very useful otherwise .. Quote
JamPS Posted September 24, 2005 Posted September 24, 2005 I would like a cropping function in DVBViewer, so I don't need to use ffdshow for that(and the new versions won't work with DVBViewer... just crashes DVBViewer). Usually there is some pixels garbage in the top of the picture that annoys me. I would like to get rid of those pixels. I hope this will be included in a future version Quote
