Mediacenter interface
Wsl
I changed overlay mode ( I think) and now program allways starts in mediacenter interface. The problem is, I cant change this or even close the program!
I must shut it in taskmanager.
good thing we removed this setting from the options of the current release. :P
go osdmenu -> htpc -> settings -> unlock htpc mode. now you can rightclick into the window open the options and disable the htpc mode setting on the first options page. Then restart the viewer.
The interface is mediacenter OSD skin in finnish! I cant find things you mentioned. Just options rolling up and down left side of screen.
Just look for home theatre or something similar in this menu and select it with enter. And try it for the above mentioned steps.
I don't know the finnish names of the menu items...
I managed to do that. Changed skin to "no skin" and restarted. Program started in OSD mode without any menu available. Then I used the install wizard again, and program is in order again. Thank You!
