Some minor UI suggestions
avoidz
Not sure if these are classified as bugs, so I'll post them here, but there are some typos and descriptive text in DVBViewer that I think could be changed.
- In the Wizard setup, in the 'Channel Scanning' window, the text reads: "The process can take serveral minutes". Typo on "serveral"; should be "several".
- In many config windows in DVBViewer, descriptive text reads: "Allows to change...". This doesn't sound correct. You could just drop the "Allows to..." part, so the text starts with "Change the...". This sounds/reads much better.
Thanks :P
Edited by avoidz
Have a look at the DVBViewer language folder -> english.lng. You are welcome to correct any mistakes or poor choices of words :P
Okay, thanks; I'll take a look at that.
I hope you just take my comments as constructive feedback, and not as complaints :P
