yoramro Posted October 4, 2007 Posted October 4, 2007 (edited) Hello, I have installed the new version 3.9.0.0 on top the previous 3.8.0.0 Every thing went OK with the installation and the Wizard. The problem is when trying to tune to any channel, the program becomes unresponsive. Even trying to kill the DVBViewer process under task manger is impossible (I have to boot to release it) My setup: Vista home premium Technotrend driver BDA 5.0.0.2 ATI HD2600XT + Catalyst 7.9 drivers. Intel 925 chipset + Pentium 630 processor I'm suspecting that the problem is related to the new features for BDA Please help Thak you Yoram support.zip Edited October 4, 2007 by yoramro Quote
Moses Posted October 4, 2007 Posted October 4, 2007 TT S2-3600 has no CI, why is that enabled in options->hardware for that device? Try to disable it. Try to rename the plugins folder. You should change options->directX->AudioRenderer back to DefaultDirectSoundDevice. Cyberlink Audio Renderer is known to cause problems and has no advantages over DirectSound. Quote
yoramro Posted October 4, 2007 Author Posted October 4, 2007 Hello Moses, You were right, the problem is with the sound device. I have changed it to the Default as you have suggested, and it works. Tnx for the quick reply and solution Yoram TT S2-3600 has no CI, why is that enabled in options->hardware for that device? Try to disable it. Try to rename the plugins folder. You should change options->directX->AudioRenderer back to DefaultDirectSoundDevice. Cyberlink Audio Renderer is known to cause problems and has no advantages over DirectSound. Quote
