Time overlaps text epg
gzez
Adjust the sizes yourself in the skinfiles. the skins are optimized for windows with normal fontsettings.
EPG Tv-Guide were time overlaps text?
Regarding- "the skins are optimized for windows with normal fontsettings" didnt have this prob in 3.6
Adding some more probs, epg-window show one 12hour and one 24hour,, bug?
Thx for fix, dont know how i get it to work, tryed copy it to "OSDSkins\Default" also tryed to rename it to myEPG.
About 12hour, dont have that problem in 3.6. so its not my provider =(
You have to unpack the .zip archive. There is a myMiniEPG.xml inside it.
Here is 24h on both positions, so reason must be the TV Station or your PC.
You have to exchange the one from the Archive with the myMiniEPG.xml from ...\DVBViewer\OSDSkins\Default\.
The DVBViewer should not be running.
And it will not change anything with 12h or 24h.
