djdul Posted October 6, 2007 Posted October 6, 2007 (edited) Hye, after an installation of the version 3.9 (on older installation)... I Have DVBSource.ini which is empty !... After some problems (BSOD...) I search in the DVBFilter and see a "buffer overflow" as last error. Looking into DVBSource.ini; the file is empty. Just reset to the 2.8.x default : [PArams] UdMaxTVRadioMS=500 UdMaxFileMS=200 UdLatency=350 and seems to works fine, again... which are the best parameters ? Hope I can help (more), on this bug ?! Thanks and regards Edited October 7, 2007 by djdul Quote
djdul Posted October 7, 2007 Author Posted October 7, 2007 ...After some problems (BSOD...) I search in the DVBFilter and see a "buffer overflow" as last error. ... no more hangs and works well all the night with the terratec cinergy XS. so can say it is solved regards... Quote
