install from scratch: existing recordings not found
Benarty
I installed DVBViewer from scratch , so also deleted the cmuv folder.
But problem is now that DVBViewer can not find the existing recordings.
DVBViewer 3.9
Select the same Recording folder. And go in the Options>Recorder and select Refresh Database.
Doesn't work for me either. All old recordings still missing after refresh. New recordings doesn't have any problems, they are showing in the list.
Old recordings are made with 3.8.0.0, now 3.9.0.0 in use.
