jannerhank Posted October 8, 2007 Posted October 8, 2007 Now I got video I have no sound. Has anyone seen a instruction book on the remote control that comes with the SkyStar 2 TV DVB-PC card? My sound works with everything else, except with the TV! This has been a battle over the last 10 days with the software as I run Vista Home Premium 32-bit. Jannerhank Quote
Tjod Posted October 8, 2007 Posted October 8, 2007 If the remote control have a USB receiver go to Options>Input->Learn-> select a instruction ->pres a remote button. Pleas post your support.zip. Quote
Zero7 Posted October 9, 2007 Posted October 9, 2007 Now I got video I have no sound. Has anyone seen a instruction book on the remote control that comes with the SkyStar 2 TV DVB-PC card? My sound works with everything else, except with the TV! This has been a battle over the last 10 days with the software as I run Vista Home Premium 32-bit. Jannerhank I had issues with TV Channels sound. I found that while scanning the channels, APID will not get added. I resolved it by adding APID manually using channel edit. This happened only with HD channels in my case. Check if APID has value 0 in them (in channel editor) Quote
