Petr Vavrik Posted October 11, 2007 Posted October 11, 2007 (edited) Hello, I think, that i found a bug in channels/stations Plus/Minus switching. For example, we have two groups and four channels in favourite list: Group A: - Channel 1 - Channel 3 Group B: - Channel 2 - Channel 4 - Correct situation: I select channel from Menu -> Channel -> Group A -> Channel 1 Now, when I switch between channels by pressing (Favourites->Station Plus/Minus buttons), i get this order: 3,2,4 .. it is correct i think, but we will be happy, if after Channel 3 it goes back to Channel 1 i think. - Buggy situation: I select channel from OSD -> ESC -> Channel -> Group A -> Channel 1 Now, when I switch between channels by pressing (Favourites->Station Plus/Minus buttons), i get this order: 2,3,4 .. it is wrong i think, is it? Suggestion: Channels order is changing,.. always if any channel has new audio track, than all channels after him has automaticaly new channel number (+1) -> it is no good i think, but i hope, that it has no effect, if i switching or typing by (Favourites->Station Plus/Minus/Number buttons), has it? And next wishes on DVBViewer developers: =============================== - Add option, that if we select any channel from OSD, it can go straight to fullscreen (now it always stay on channel lists) - Remap first channel to position "1" and NOT to "0" (it is realy important for comfort, because every remote control start with numbers "1,2,3,..") - If we go to OSD Favourite list, show me current selected channel and in right group (now it always show main "favourite" groups) - OSD -> TimeLine: is not builded from channels in current selected favourite group but from global channel list?,.. please, add option to choose it - OSD -> Now: is also not builded from channels in current selected favourite group but from global channel list,.. please, add option to choose it - Add option to set CD/DVD speed for playing AudioCD/DVD-Video Sorry for this long post and thanks for your effort. Yours faithful user PS: I use PCI SkyStar2 (rev.2.6d) & (drv.4.4.1), but same problems is on SkyStar HD, mainboard is MicroStar 945GT Speedster-A4R (VGA integrated Intel GMA 950), all has last drivers. support.zip Edited October 11, 2007 by Petr Vavrik Quote
Moses Posted October 11, 2007 Posted October 11, 2007 - Add option, that if we select any channel from OSD, it can go straight to fullscreen (now it always stay on channel lists) That's already there. Have a look at the "hiddensettings.txt" or "tweaks.txt" in DVBViewer Folder. You will need to know where your configuration folder is, DVBViewer tells you in menu->info. - Add option to set CD/DVD speed for playing AudioCD/DVD-Video There are pleeeeeeeeeeeeeeeeeeenty of tools to do that. Not everything needs to be done by DVBViewer... Quote
