DVB viewer version 3.9.0.0
mitch26
the transponder list item Atlantic bird 3 and the .ini file do not seem to match. I have updated the .ini file but it seems that the DVBViewer aplication fetches a different .ini file to start scanning.
Please find attached the support file.
I use a Technotrend S2-3200 TV card with driver 2 5.0.0.2, my motherboard is ASUS P5GD1 PRO with chipsets Intel 915P and ICH6R and my graphics card is ATI EAX 1660 PRO SILENT 512MB DDR2 with driver 6.14.10
DVBViewer use the transponder .ini in the (About>)Configuration folder \Transponders.
Thanks, since my initial post, I found that I had only updated the transponder file in the program files DVBViewer folder. I also had not uninstalled the previous version 3.6.1 correctly. All works fine now thanks again for your help.
