dvd audio missing
juhoaj
hello! i have the following problem:
audio works ok on dvb-c and audio cd, but when DVBViewer plays dvd discs the audio is dead. changing the audio track from 5.1 ac3 to 2.0 stereo does not help. dvd audio works ok on windows mediaplayer. i have tried all the in the DVBViewer dvd audio options, and nvidia purevideo, ffshow and ac3filter codecs .
i believe that soundmax and codec settings are ok (i have tried multiple settings, including "computer speakers" and "tuner" 2.0 analog settings).
system:
- audio connected from audio out to plasma audio in (RCA)
- xp sp2 (clean install)
- DVBViewer 3.8.0 (clean install)
- integrated soundmax (adi ad 1888)
any help/link is appreciated, i did not find anything with forum search or google.
Edited by juhoaj
Try a different DVD Audio decoder (Options>DVD Options).
If it did not help Install DVBViewer 3.9.0.0 and post the support.zip
thank you for your quick reply.
i did try all the listed codecs. no luck.
update to 3.9.0.0 did not help either.
attached is support.zip
I think AC3Filter is the best choice.
But i have no idea way it not works.
Has the DVD a Finnish Audio Track?
Try English as Audio.
That did the trick.
I set the audio track to english in the dvd options. now all audio tracks, including the finnish track work well :-)
thank you for your help.
