Usals / diseqc problem with version 3.9
subdvbv
I have entered my position in Diseqc editor (lat 52.6 N, long1.80W) but cannot lock onto any satellites via Diseqc, Goto angular, Usals (or command string) configuration (the motor does move well though).
(Progdvb and a SS2 card works ok and when I connect the dish to the Floppydtv / DVBViewer it works ok- The problem occurs when I try and use Diseqc with DVBViewer)
Is this a bug with version 3.9 and can anyone help?
I am using a floppydvt-s2 card with a HH120 Stab motor.
Is this problem related to the West satellite issue ?
thanks for your time.
