Jekkaman Posted October 14, 2007 Posted October 14, 2007 (edited) After installing correctly the driver the program detects the card "technisat digital tuner" but when i click on a channel or try to scan nothing happens,when setting a channel it shows up Hardware not found. support.zip Edited October 14, 2007 by Jekkaman Quote
Tjod Posted October 14, 2007 Posted October 14, 2007 Install the not BDA Driver. The Technisat BDA driver 4.4.1 did not work with any Software. Quote
Jekkaman Posted October 14, 2007 Author Posted October 14, 2007 Install the not BDA Driver. The Technisat BDA driver 4.4.1 did not work with any Software. I also tried to install the "network" driver the program shows "technisat digital tuner" . Quote
Tjod Posted October 14, 2007 Posted October 14, 2007 Delete the Device in Options > Hardware and click Scan Devices. After a restart it should work. Here it do. Quote
