Scanning first time setup
stianbarmen
Hello, I just bought and installed the 3.9 version but I have problems scanning channels.
I have a floppy dtv-c card, latest driver and firmware. I know from using mediaportal that I should use symbolrate 6950, but I don't understand how to scan this from the setup of DVBViewer. I tried the quam 64 parts, because I googled someone else doing something similar.
Anyways, my provider is Canal Digital in Norway, CAM is Conax. All works perfect in mediaportal (though unstable for me...).
Any tips how to tune my channels? Thanks. :bye:
skip the wizard, open DVBViewer, select channel->channel scan. Select "cable" as reception type. If you have, select the correct transponder file. If not, select "none" and you can configure your symbolrate. But your scan may take a while.
