Danish Posted October 15, 2007 Posted October 15, 2007 Hello Support Folks I cant seem to retrieve any channels when performing a scan. The signal strength meters shows I have signal and creeps up to 100% but by the end finds 0 channels. This setup works fine with other software (Mytheatre) but can't seem to find any channels with DVBViewer. Attached support.zip Thanks for the help! support.zip Quote
Zero7 Posted October 15, 2007 Posted October 15, 2007 Hello Support Folks I cant seem to retrieve any channels when performing a scan. The signal strength meters shows I have signal and creeps up to 100% but by the end finds 0 channels. This setup works fine with other software (Mytheatre) but can't seem to find any channels with DVBViewer. Attached support.zip Thanks for the help! i have the same problem. I use Transedit to scan the channels and "send" the scanned channels to channel list. It helps me in saving the transponder settings at the same time. I did not bother much about not able to scan in Channel Scan window. Quote
