Record both MP2 and AC3 audio in .ts?
ceekaay
Hi, is it possible to somehow record both MP2 and AC3 audio in DVBViewer somehow?
I'm a regged user and i'm using version 3.9.0.0. (technotrend dvb-s2 3200 card).
So,
When i scan channels i get 2 channels of the MP2/AC3 airing channels,
so when i hit record on any of those "copies" of the channel i will only
get either a ac3 OR mp2 track in the .ts file, not both as i get with other softwares like altdvb.
but DVBViewer has much nicer features and is 100% stable so i would really like this to work somehow =)
i have the "record all audio channels" box checked.
Thanks in advance!
//regards ckz
It should work. If it happened on encrypted channel may be a problem with you CAM.
