Accuphazee Posted October 16, 2007 Posted October 16, 2007 (edited) [Deleted] Let's well write laconically so - give the chance choice Ident in the program. Give a point of a support and the world will turn over about the axis. It is senseless to be at war with windmills. Thanks. Edited October 16, 2007 by Accuphazee Quote
Griga Posted October 16, 2007 Posted October 16, 2007 It is senseless to be at war with windmills. That's true. And it is senseless to be at war with the forum rules. So please don't repeat something like this, otherwise we will have to disable your account. Thanks. Quote
Accuphazee Posted November 2, 2007 Author Posted November 2, 2007 (edited) DVBDream 1.4 has possibility of a choice ident. But cannot work with ÀÑ3 yet (from a stereo there are no problems). And the train moves further and anybody will not wait. Edited November 2, 2007 by Accuphazee Quote
Lars_MQ Posted November 2, 2007 Posted November 2, 2007 I can happily say I have no clue what you're talking about and i don't care Quote
Accuphazee Posted November 2, 2007 Author Posted November 2, 2007 (edited) The program which possesses all possibilities for you will buy not for 15 euro - and without problems even for 100-120 euro. It simply business and anything else. Nobody pursues the manufacturer of the weapon or for example Dreambox - for the fact of production of these subjects. Responsibility lays on the user. It is a pity, but your program one of the best in the market for DVB-S2. All the same this problem will be solved. Probably others which it is very good on it will earn. Example: program ProgDVB (cannot normally support DVB-S2 and BDA) which in Russia practically anybody any more does not use. It simply interests nobody. Edited November 2, 2007 by Accuphazee Quote
Accuphazee Posted November 17, 2007 Author Posted November 17, 2007 (edited) Time is not necessary on a place and there was a second program - AltDVB 2.2 with BDA interface 0.1.0.1 which allows to choose IDENT (for TT S2-3200) [Deleted]. Edited November 18, 2007 by Tjod Quote
buklov Posted June 3, 2009 Posted June 3, 2009 me too interested in how to choose the correct ident part of ntv + channels is not working there 2 idents in progdvb all ok, bat i'm buy DVBViewer!!!! Quote
