deggesim Posted October 16, 2007 Posted October 16, 2007 (edited) Before the upgrade, I made a backup of the folder DVBViewer in C:\Documents and Settings\All Users\Application Data\CMUV (I hope I remember well the path). Now I have reinstalled the software on Windows Vista. I'd like to use the old configuration to retrieve all my settings. I looked for a similar folder but I did not find the Documents and Settings staff. I discovered with a simple google search that threre is an hidden appData folder in the profile folder instead of the D&S folder... But I did not find any CMUV folder... Where is it? Thanks everybody for your answers. Edited October 16, 2007 by deggesim Quote
Tjod Posted October 16, 2007 Posted October 16, 2007 Start the DVBViewer -> About > Configuration folder will open the wright folder. Quote
