Record does not work (V3.9)
jascdvb
Hi
installed the V3.9 yesterday. Worked fine, but clicking on record does not work. Nothing is recorded. It says on switching "No hardware available" but there is no file created
Any help??
I had V3.8 (or 3.8.x) and no problems there
Regards
Jan
Edited by jascdvb
Sorry, I searched for a post but didn't find one
Searched for something else a found the post saying that this bug is know and is caused by a setting for splitting the record files
Now it works
Hello,
i have exactly the same problem with the new version. My Hardware is Skystar-HD
Can anybody please help getting DVBViewer 3.9.0.0 working?
Regards,
Canislupus
EDIT: Problem has been resolved by reinstalling DVBViewer. It works now ...
Edited by Canislupus
As jascdvb said: it's a known bug, just disable / don't enable the "split after xx MB" option in DVBViewer -> Options -> Recorder.
